Broken BF-2
Started by blooze_man, July 29, 2010, 06:26:16 PM
blooze_man
I was hunting down circiut bends in my BF-2 (found a cool one) and for some reason my pedal no longer turns on, does not pass a bypassed signal and has a very audible ticking. I can only assume I shorted something while I was poking around with a wire. Any help is appreciated. Thanks.
Big Muff, Trotsky Drive, Little Angel, Valvecaster, Whisker Biscuit, Smash Drive, Green Ringer, Fuzz Face, Rangemaster, LPB1, Bazz Fuss/Buzz Box, Radioshack Fuzz, Blue Box, Fuzzrite, Tonepad Wah, EH Pulsar, NPN Tonebender, Torn's Peaker...
RedHouse
Not to hijack this thread, but does anybody have the service file for the BF-2?
Not just the schematic (which I already have) but the other pages which show the setup of the trimmers and voltages?
Derringer
Quote from: RedHouse on August 12, 2010, 08:49:06 AM
this help?
"Adjustment procedure:
1.) Clock frequency adjustment:
Set MANUAL and DEPTH knobs to full counterclockwise. Connect an oscilloscope to TP-1 test point. Adjust VR7 for T=25us (40kHz). Rotate the MANUAL knob fully clockwise. T should be 2uS +/-20%.
2.) BBD bias:
Set DEPTH and RES. knobs full counterclockwise. Feed a 200Hz, sine wave, 0dBm signal into the INPUT jack. Connect the oscilloscope to Q3's emitter. While turning MANUAL across its entire rotation range, set VR6 for a clip-free waveform at the peaks.
3.) Resonance:
Set MANUAL, DEPTH knobs full counterclockwise and RES. knob full clockwise. Plug short circuit into INPUT jack. Connect OUTPUT jack to an amplifier and speaker. While touching a screwdriver to TP-2, set VR5 to the point where oscillation begins. "
Derringer
Quote from: blooze_man on July 29, 2010, 06:26:16 PM
the only advice I can give is to go back and check everything. Is the pedal modified now? Undo the modification and try to get it working stock again.
here's the info I used when I modded mine
http://www.hobby-hour.com/electronics/s/boss-bf2-flanger.php
RedHouse
Quote from: Derringer on August 12, 2010, 09:56:33 AM
this help?
2.) BBD bias:
3.) Resonance:
Yes thanks. You wouldn't happen to have a scan of the doc would you?
(or that PDF that was going around on the internet a while back)
Derringer
#5
I have two of these pedals, but bought them both used and neither came with the original papers
this is all I've got to go on
but I see it shows where the test points are so you should be good
RedHouse
Quote from: Derringer on August 12, 2010, 10:06:40 AM
That's perfect thanks, the diagram below the schem is from the other page of the service doc.
I used to have that doc up until a HD failure in my desktop PC (no backup of course), anyway thanks for the pointer.
Steve Newton
I have these 2 pages of the service manual. No idea if there are more and this is all i can find. But it does have details  of the calibration procedure on the second page.
Steve.
Not my circus, not my monkey.
RedHouse
Quote from: Steve Newton on August 12, 2010, 01:11:01 PM
Very good Steve, thanks for that.
