I bet someone knows Right Where those//
Started by petemoore, December 06, 2003, 04:30:24 PM
petemoore
Small Stone Mods are.
 First at bat is the Volume drop. Compare and contrast at will about tweeking existing ckt or simply Boost [with extra active componint] the output. ..
 Small Stone YEAHHH !!!!!!
analogguru
If you go at my homepage to Manufacturers/Electro-Harmonix you will find Issue K Russian, I put it there for you, but i will remove it soon, because it takes to much web-space (I can put in the same space 6 Hi-Q schematics).
The schematic is right, only on one unit I found different values as follows:
R4 470k, R24 27k, R25 470k, R26 27k, R27 3k62, R 39 1k6
Q2 - Q4 are 2N5087
good luck, analogguru
www.anubics.com
MRTelec
Quote from: analogguruIf you go at my homepage to Manufacturers/Electro-Harmonix you will find Issue K Russian, I put it there for you, but i will remove it soon, because it takes to much web-space (I can put in the same space 6 Hi-Q schematics).
Q2 - Q4 are 2N5087
www.anubics.com
Wow, I've never seen that site before.  It has tons of useful stuff.
petemoore
I've broused around the Moosapotamus's site many times and have not seen any tweeks or schematics...I think I'm missin them somehow...
