1/4 watt or 1/2 watt???
Started by cobainlives_05, December 12, 2003, 08:39:36 PM
cobainlives_05
is it ok to use a 1/2 watt resistor when it says to use a 1/4 watt?
RDC
Peter Snowberg
Absolutely :), just don't use a 1/4 where a 1/2 watt is specified.
The wattage rating just tells you the maximum amout of power the resistor will take before it starts smoking. You can always use a larger one as long as you can fit it.
Take care,
-Peter
Eschew paradigm obfuscation
petemoore
petemoore
For 9v [i think 18v or even 36?] 1/4w R's are fine as 1/2's are...1/2w's are bigger physically and may take up more space than you would like so watch for that.
cobainlives_05
phew, there is so much to learn about making stompboxes!!!
RDC
