I'm repairing a Marshall MG100DFX solid state amp. The TDA7293 chip had blown and damaged a couple of the caps on the daughter board with it. The amp has a headphone output, so I removed the board with the TDA 7293 and tested the amp. Everything works on headphones, so everything works up to the master volume control. After the master volume, I have good continuity between all components all the way to the speaker output.
Here is a link to the Marshall schematic:
http://www.amprepairparts.com/mg100dfx.pdfHere is a link to the TDA7293 datasheet:
http://www.st.com/web/en/resource/technical/document/datasheet/CD00001887.pdfI replaced the TDA7293 and all the caps on the board with it. I have correct voltages to all the pins on the amp chip - except for pin 9 - and I get no output to the speaker.
The TDA7293 pin 9 gets a voltage from the output of TR2 (C3198) in the power supply section. TR2 is in the power supply section at the bottom of the page with the power supply. The supply voltage in that section is +12 volts. However, the voltage I read on the base is -0.5V. On the collector it's -0.2V. Can't be right. I think the voltage on the collector should be at least 3.5V.
The diodes D14 and D17 were tested OK in the circuit. Is this just a failure of TR2, or is there something else I should check?
Here is a link to a datasheet for TR2, (C3198):
http://www.ic72.com/pdf_file/c/c3198.pdf
