CHASM REVERB
Started by deadastronaut, November 20, 2013, 12:50:02 PM
hi, use a dpdt footswitch,
one half switches the osc..on/off
the other half used for led...
8)
Lothric
thank You so much Sir   ;)
your very welcome....have fun.  8)
Lothric
once again BIG BIG thanks, thing is fixed now, and works like a charm! During Saturday band session we will fly up on the Moon  ;)  ;D
cheers, have a great flight....watch out for a little russian dog floating about... ;D
Mrchroni
Hey. New on the board and not sure if anyone is still on this thread at all but figured I'd check. Currently putting a chasm together (super excited to get playing on it) and just thought I'd see if anyone has a wiring diagram. I'm sure I'll figure it out just seeing if could save myself a little headache as I always seem to mess something up while wiring. Thanks!
Hi, yes were still alive.. ;D
there is a pdf on my site with switch wiring...
Look below ...
rob
Mrchroni
#507
Thanks rob! Can I be needy (I'm obviously a novice at this) and ask to see if you or anyone else out there has a diagram or detailed gut shot of the full wiring including jacks and power? Sorry to be a pain in the butt. Thanks!
Jdansti
Quote from: Mrchroni on March 04, 2017, 01:43:04 AM
Here's one on page 4 of this thread: http://www.diystompboxes.com/smfforum/index.php?topic=105109.msg950530#msg950530
There may be other examples within this thread.
Cheers john,  8)
if i get a mo later i,ll knock something up too ok......you needy bugger  ;D
wiring guide. a little late, but dropbox changed the way they let you link ...the bstds. :icon_rolleyes:
gcol
I just finished building my chasm reverb and it worked for about 5 minutes then all of a sudden it started making this really loud, distorted noise that was so loud I had to turn the amp off. Any ideas on why this might be happening?
Check your 5v reg is around the right way...
voltages, and pictures will help.
Add your toggle switch....
Yep thought so,  flip that reg around...
the 7805 is opposite to a 78l05.
edit:hopefully you haven't damaged the brick...fingers crossed
gcol
shit :/
I flipped it round and the light still comes on but sounds the same, just like a really overloaded sound that increases when I turn the volume pot up. Sound doesn't change when I turn up any of the other pots though...
hmmmm....shit indeed.  :-\
basically you have fed 9v into a 5v brick...oops!!!. not good..
do you have 5v going to brick pin 1 now then?.
gcol
Yea I pulled out the REG1 and soldered it back in the right way but worried I might have fried the brick  :(
