Author Topic: Wedgies Anyone? A 1590B tutorial  (Read 38546 times)
Re: Wedgies Anyone? A 1590B tutorial
« Reply #60 on: April 13, 2015, 11:08:13 AM »
I'm no metal worker either, but I do own a hammer, and I love watching (community access tv) programs where the bloke hammers a flat sheet until he has a new bonnet for an FJ, or something. if yr Al box has those real big crystals of aluminium showing, I think they'd be more crackable than bendable.
maybe it's just the crummy cases I've seen is the problem.
Now battery powered. Remove plug when not in use, please.
Cozybuilder
« Reply #61 on: April 18, 2015, 02:52:13 PM »
How appropriate that Mister DA posted just before this!
As promised, here is the completed build using the wedgie. Circuit by Sam Hay, just a couple of mods. Thanks to Michael (Whiskey Made Me Do It) for a lot of help in pulling off the graphic.
« Reply #62 on: April 18, 2015, 03:18:00 PM »
Super job Russ, came out great!
Thanks for the tutorial, makes for a very cool little box in a flavour different  from the norm.
dave
bloxstompboxes
« Reply #63 on: April 18, 2015, 03:30:39 PM »
Holy crap! That's a lot of jumpers. lol. Good job.
Perrow
« Reply #64 on: April 18, 2015, 06:10:14 PM »
If you start off with a 125B enclosure you'll have five extra millimeters of height to begin with.
Cozybuilder
« Reply #65 on: April 18, 2015, 06:29:09 PM »
Pelle-
Agreed, 125B would make it a lot easier- you could fit open frame jacks in the back along with the 9V Jack, and use the large blue 3PDT switch. I hope to see other builds  ;D
Crowella
« Reply #66 on: April 18, 2015, 06:52:37 PM »
Bookmarked this thread. That's a really tidy job that I feel a lot of people can do easily. Kudos.  ;D
Rhythm in jump, dancing close to you
« Reply #67 on: April 19, 2015, 07:46:24 AM »
cozy - I never thought I'd read a comment like that. outstanding looking thing there, even without a footy.
[change yr name to purple fuzz in a week's time, and I might have something to show after one of your posts.]
plexi12000
« Reply #68 on: April 20, 2015, 02:48:51 AM »
nice work-- looks cool!
peterg
« Reply #69 on: April 20, 2015, 08:44:48 AM »
Russ - looks good! What's next? A 1590a box wedgie?
« Reply #70 on: April 20, 2015, 09:47:01 AM »
nicely done... 8) 8) 8)
Cozybuilder
« Reply #71 on: June 04, 2015, 08:35:09 PM »
Heres another in the Wedgie enclosure. Its a modified Axis Face.
I almost feel guilty that there is so much room in there!
« Reply #72 on: June 04, 2015, 08:43:26 PM »
Ah... room to breath, nicely done Russ!
Luke51411
« Reply #73 on: June 05, 2015, 09:34:23 AM »
Nice pink wedgie! I'm still waiting to see you turn a 1590A into a wedgie... :icon_mrgreen:
« Reply #74 on: June 05, 2015, 09:39:01 AM »
I can't say I would have going to the trouble of doing that!    Some of you guys are so keen, it's amazing.
The internet:  answers without the need for understanding.
Cozybuilder
« Reply #75 on: June 05, 2015, 11:51:36 AM »
Thanks for the kind words guys.
I built 2 of these, with a couple of changes in the coupling caps, and the reverse polarity protection. You can use a 1N4148 or other diode (forward voltage drop about 0.7V) or a BS250 (P-channel MOSFET, forward voltage drop about 0.03V).
Here is the schematic and the perf layout. This layout could easily be done as a PCB.
Cozybuilder
« Reply #76 on: June 24, 2015, 11:02:34 AM »
After seeing a 1968 Vox ToneBender V828, this looked like a reasonable next step in the development of a practical Wedgie from a 1590B. I wasn't trying to duplicate it, but rather capture the essence of the original.
This project started with the steps outlined in the first posting, making a wedgie, with a couple of additional steps, and a method to assure the bottom pieces are in the same plane and end up with a usable box.
1) Here is the basic layout. I adjusted the pot location from the pictured build to better center the knobs in the graphic:
2) Before making any cuts, drill for the 9V and I/O jacks first. Its much easier to clamp the rectangular box than the wedgie. The other holes are easily done later. The basic wedge box is formed with the cutout of the wedge, then the top. Best to cut the bottom (angle) of the wedge shape first, then the parallel cut to the top, then cut across the top. Band saw preferred, hacksaw a little more work but very doable, last choice is a dremel cutter. Once the top has been cut off, file or sand the two pieces to a good fit.
3) Mark your lines top and bottom. My build divided the width by 4 (0.58"), and cut that amount. I think thats excessive, and would recommend a smaller dimension, maybe 0.40" - 0.45", instead. On the bottom plate, measure the distance the screw hole center is from the edge, and mark that on the edge. Draw a parallel line to your cut line, and measure up to it.you will align the side piece by screwing into the boss.
4) Now cut the angle piece from the top, side, and bottom on ONE SIDE ONLY. Be sure the bottom and top are on the same side. Cut and fit the front and side piece to match up, and use a dremel to do the relief cuts on the bottom lip so that you can screw the side to it. Once everything fits well, JB Weld the top to the cut side, the top, and along the front, do not glue the portions that will be cut in the next step. Use all 4 screws in the bottom plate for aligning. After cure it should look like the second photo below.
5) Now do the same steps on the other side. This one is a lot easier than the first. Fill in any shallow places, radius the inside edges etc.
6) You will need to form a new lip in the bottom plate, you can just use the wedge piece you cut out as the base material. Take a little time with the dremel and JB Weld and you can make it look better than I did.
Heres the completed project (so much unused space   :'():
So, a fiddly project that will give you a little different flavor. Heres a family shot of the three wedgies done to date:
« Last Edit: June 25, 2015, 03:33:40 AM by Cozybuilder »
« Reply #77 on: June 24, 2015, 11:53:20 AM »
now that I've seen how you did the toe-taper, nice work. you're mad, but nice work anyway.
and aren't all fuzzes pink?
Cozybuilder
« Reply #78 on: June 24, 2015, 12:07:16 PM »
I'll take that as a compliment Ducky, thank you! Pink just didn't suit this "tribute" pedal, but yes most of my distortion-type pedals are pink.
« Last Edit: June 24, 2015, 12:09:00 PM by Cozybuilder »
« Reply #79 on: June 24, 2015, 04:45:35 PM »
+1    (Quite, quite mad...)
