I built it and I'm very happy with it. I leave it on almost all the time. Lots of squish available at high settings if you want it, very subtle at low settings if you prefer that. I found it a bit dark, stock, so I added a bright mode on a switch. I also increased the coupling caps a bit so I could use it on bass as well.
I got some distortion at high settings at first. I pulled out the ldr I had scavenged from some home appliance and replaced it one from the Radio Shack assortment pack, and the distortion went away.
