troubleshooting a biuld - basic diode question
Started by plexi12000, May 14, 2017, 11:13:16 PM
plexi12000
hey tone gods......  using the ol MM....it seems in my power supply, I have a break in, or around the polarity diode.   I have 9v before it, but not after it.
if not a poor solder joint....suppose I overheated it and cooked it.  will a diode still pass current?
Thank you!
GGBB
If it fails, it fails unpredictably - either open, short or somewhere in between (resistance). The latter two pass current.
antonis
If your polarity protection diode is in series with +9V, then you've probably burned it out..
(but, if diode is a 1N400X type, then you've probably burned out some other following items..)
If it's in parallel with + & -, then you have a short circuit which should have blown up your fuse..
(or your PS in case of an unfused one..)
GibsonGM
So, what kind of diode was it?  1N4148, or 1N400X type?    Is it black with a silver band, or glass?
Quote from: GibsonGM on May 15, 2017, 08:16:33 AM
Or, is it too charred to tell?  :icon_razz:
GibsonGM
"Can't find what's wrong with it, sorry. I spent hours last night going over the board, even hooked up some external speakers...nothing.  Are you sure your outlet at home has power??"
Quote from: EBK on May 15, 2017, 08:50:24 AM
that board's been hit by the Mother Of All Diodes.
An administration error has occcured. Please wait.
