Author Topic: Boost AND Coil tap???  (Read 236 times)
boogietube
« on: March 07, 2018, 09:18:20 AM »
A friend of mine is building a Telecaster with one double coil pickup in the bridge position.
He wants to be able to have a boost and a coil tap in the guitar. Here's the problem: he wants the boost AND coil tap to happen at the same time with one switch (preferably a pot with a switch) Is this even possible? I'm stumped.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
Re: Boost AND Coil tap???
« Reply #1 on: March 07, 2018, 09:31:30 AM »
3PDT, use two poles for the boost bypass and the third pole for the coil tap. Unfortunately I don't know of anyone that makes a 3PDT push/pull pot, so it would have to be a separate toggle.
"I'm not sure what "serious design flaws" you see. Does it explode or poison your dog?" - PRR
"Tayda's Whipping Boy" "Most Detestable Forum Member 2018"
http://www.sushiboxfx.com
boogietube
« Reply #2 on: March 07, 2018, 10:05:55 AM »
ya, I thought so. Thanks.
« Reply #3 on: March 07, 2018, 01:01:32 PM »
Hi Sean, long time no see.  Nice to have you here again.
