Reckless compressor - an original feed-forward diode based compressor
Started by jonny.reckless, July 20, 2018, 05:13:43 PM
andy-h-h
Hey bowanderror - I changed the 1k to 10k based on this post (link below).  10k uses less current than 1k.  I also used 100u caps just based on physical size for power filtering.  Of course you could always go bigger if you have something compact.   I've made a couple of these, and have never had an issue with noise.  I think it's a great compressor.
https://www.diystompboxes.com/smfforum/index.php?topic=122568.20
I probably updated the layout since the previous post.  Think I have some smaller options listed.   Good luck with it.
Quote from: jonny.reckless on March 02, 2022, 09:15:50 PM
I don't have any PCBs left for the diode compressor(s).
PCBs for rev A and rev B of the diode compressor:
https://drive.google.com/drive/folders/1Apz7R7oSrA2EcCY_PMb7qlkBFp01aJwr?usp=sharing
Hi Jonny, I've bought PCB for this from you long time ago, now started to populate and noticed that 3PDT board has holes for some kind of a small PCB-mounted jacks? Could you please give me some clue what kind of jacks did you use, or even better, mouser part number? Thanks!
jonny.reckless
Quote from: rankot on January 08, 2023, 03:03:02 PM
They are Neutrik NRJ4HF jack sockets as listed on the bill of materials for the compressor. You can get them from mouser.
https://www.mouser.com/ProductDetail/Neutrik/NRJ4HF?qs=XYKw4GFm8i25NTiqJyBUbQ%3D%3D
bartimaeus
Finally build a Rev B of the Diode compressor earlier this year, and I'm loving it!!
Not sure if it's the feed-forward design or the diodes, but it contrasts nicely with my Pellucid compressor.
That said, I'm thinking it would be nice to have the option of a softer knee or a softer ratio...
Anyone have thoughts on adding a ratio control to this? Or would I be better off building an Engineer's Thumb?
Also, I'm curious what makes the Rev A Diode comp sound more transparent than the Rev B? Does the smoothed dual supply do a lot of work?
