power transformer for 12AU7 D.I. box
Started by Dimitree, October 05, 2018, 09:35:10 AM
Dimitree
hi everyone,
I'd like to build a simple clone of the AMPEG SVT-DI box.
it's pretty simple, for the output transformer I'm going to use a Jensen JT-DB-E (should be right for this job I guess).
I just need to find a power transfomer.
Do you have any suggestion about a particular (I prefer cheap  :icon_razz:) transformer that I could use?
thanks
wavley
Bone is in the fingers.
EccoHollow Art & Sound
eccohollow.bandcamp.com
Dimitree
Thank you! Looks pretty cool but unfortunately I'm in Italy and Weber has got some pricey shipping options to Europe, this would cost me about 100$
wavley
Quote from: Dimitree on October 05, 2018, 10:12:38 AM
Scroll down to the bottom of this page and check out the low power transformers here https://hoffmanamps.com/MyStore/perlshop.cgi?action=template&thispage=Transformers&ORDER_ID=792456230 they're the same ones as EHX tube stuff.
Dimitree
Quote from: wavley on October 05, 2018, 10:24:04 AM
that one looks great, but is it safe to use it in reverse like that?
I've seen people using two of them, like this: 220V -> 12V -> 12V -> 220V
would that be wiser?
wavley
Quote from: Dimitree on October 05, 2018, 11:15:15 AM
That's the way all of the EHX tube pedals are and I haven't seen any problems in the two I own.  You use the flatpack transformer with a wall wart that puts out 12VAC, pull the heaters off of the wall wart in parallel with the input of the flat pack so that way you get a heater and an HT out of two transformers, the wall wart providing any isolation from the wall you need.
The drawing shows a DC heater supply.  Once you rectify the 50/60 Hz input, you generate harmonics that extend into the audio range.  The fundamental will be below the flat part of the bandpass and it should not be too much of a problem to go without rectification and filtering.  The best thing to do with the heater voltage is to raise it to a positive level above ground.  That way, any emission from the heater itself will be stopped by the grid post which will be approximately at ground.
