Making your own knobs (need some help)
Started by FUZZZZzzzz, March 04, 2019, 06:01:22 AM
FUZZZZzzzz
So, I've decided to make my own knows. I'm making moulds and I'm using resin that i can color as well. It looks very nice. I'm making some copies of old knobs from radios etc.
I'd like to make them with a 6 mm push on shaft, so I dont have to drill a hole in the side for a set screw. Does anyone know if its possible to buy the 6mm push part? I would like to drill a hole in the bottom and glue the push shaft into place so it makes a nice 6mm hole.
I dont know where to look for on google. Preferably some kind of metal (material not music)
any ideas. i know i can just buy cheap knobs and take the part out.. but thats not really what im after.
FUZZZZzzzz
they have to fit something like this.
something similar to the brass part maybe
Phoenix
Why not just mold the 18 tooth spline/knurl? That's how they're made commercially.
https://www.ebay.com/itm/BUSHING-PARTS-FOR-MAKING-YOUR-OWN-CUSTOM-GUITAR-KNOBS-/202482591760?oid=200511973806
from another thread - found searching. you need to know the number of splines ..................
and:
https://www.bitterrootguitars.com/Knob-bushing-for-6mm-shaft-p/152001-50p.htm
that "brass part" is the collet and nut in a collet knob. sifam and alma make the knobs, dunno bout spares.
FUZZZZzzzz
Quote from: Phoenix on March 04, 2019, 08:22:10 AM
Thats true.. i can mold them even with a pot shaft inside, but the placing, depth etc would be critical.
FUZZZZzzzz
Quote from: duck_arse on March 04, 2019, 08:45:17 AM
and:
thank you!
Thonk in the UK sell these set-screw brass inserts:
  (click)
I'm sure there must be other vendors selling the same thing?
I have seen a knob for an antique radio being 3-D printed at one meeting of the London Vintage Radio Club.  This seems to offer a lot of promise for rare or hard-to-get knobs but the process takes over an hour for even a small knob.  Plaster mold casting may be competitive and I have one book on the subject:
How to Cast Small Metal and Rubber Parts by William A. Cannon
It is a small book but it covers investment (lost wax) casting, die casting, permanent mold casting, plaster casting and shell mold casting.  It has chapters on molding with a defective pattern and molding with a metal insert.  Some of it will be applicable to casting plastic and there are some casting resins that can be used in the same manner.
