A build for a friend. The usual - 2 SRPP (the real ones) jfets with a FMV stack and a jfet output buffer. Always thought about a boost switch, never could get it to work properly. Then pedalpcb started to sell the "Tweed Man" overdrive, a copy of the Catalinbread Formula 5F6 WITH A BOOST SWITCH. So I copied the switch function
The other values and parts are (almost) as I already had them. Given a year or two more, I'd have copied the 5F6 pedal without knowing it
But, I must confess, I also took the hint and tried those 4393 jfets - with success.
Fabric is off the leg of my first ever "Business" suit for work.
