Suggestions on a voltage doubler
Started by whomeno, October 06, 2019, 05:48:20 PM
whomeno
I built a noisy cricket mk2 amp. Would like to take
The 9 volt to 18 volt inside the case. Which doubler
Would work best.
Gear as of now
Gibson 2017 Les Paul Tribute T
Epiphone Les paul Special (upgraded)
Marshall DSL 20 Head
Peavy Valve king 20 W
2 X 12 Cabinet with celestion vintage 30 & celestion G12T-75
And a lot of pedals
Raising the voltage on a LM386 does not raise the power, much. It mostly over-heats the chip.
Small/simple doublers don't support the power you hope-for from a 18V power amp.
There are other choices which will work better. BTL doubles the speaker voltage for the same supply voltage.
whomeno
 BTL doubles the speaker voltage for the same supply voltage ?
can you explain more?
I am using the lm386n-4 which will handle the voltage.
Hoping to get a little more headroom on it
Gear as of now
And a lot of pedals
But not the current. It is a very teeny chip inside.
Others will know more about what chips can make some power from 9V; I'm not hip on the current crop.
radio
If  2 Watt is enough and you don't bother building a more advanced project,
here is a Marshall Guvnor with 2 LM386-3 in bridge configuration as power amp,
designed  by Michael Massberg in 2004:
members.aon.at/cgm/Little Rebel/little rebel.pdf
Keep on soldering!
And don t burn fingers!
