Author Topic: Digitech Digidelay Repeat problem?  (Read 321 times)
Kimon
« on: May 14, 2020, 06:32:52 AM »
Hello everyone.
I am experiencing a strange issue with Digitech Digidelay and would like to be able to confirm it is indeed a fault:
When the "repeat" knob is at "10" (full on) https://speedtest.vet/ https://vidmate.bid/ there seems to be no repeats at all - only dry signal.
Backing it to about 8-8.5 brings on the delay\repeats as they should.
I cleaned the potentiometer (even though is is a sealed type square pcb mounted type) to no avail.
Is my copy defective? Have any other members experienced the same behavior?
Thank you in advance.
« Last Edit: May 15, 2020, 01:39:53 AM by Kimon »
Digital Larry
Re: Digitech Digidelay Repeat problem?
« Reply #1 on: May 14, 2020, 08:48:38 AM »
Don't have one, but that sure sounds like something is wrong with the pot.  Cleaning can't fix everything.  How old is it?
Digital Larry
DSP tinkerer and former transistor twister
