Author Topic: Chip amp in bridged mode  (Read 218 times)
John Lyons
« on: February 02, 2021, 03:31:51 PM »
I've built this twice now on the breadboard at 9v
without success. I added an emitter follower/buffer
to get some more clarity for guitar.
It has a low oscillation with the buffer and sounds choked
and misbiased built just as in the image.
I have the Stereo/unbridged version working fine with the buffer.
I tried adding more filtering but I'm not sure where else to check.
Any ideas?
Basic Audio Pedals
www.basicaudio.net/
Gus
Re: Chip amp in bridged mode
« Reply #1 on: February 02, 2021, 03:47:12 PM »
What is the speaker ohm rating that you used in bridged mode?
antonis
« Reply #2 on: February 02, 2021, 03:52:11 PM »
Try to ground pin 13 as close as physically possible to 150nF caps ground..
John Lyons
« Reply #3 on: February 02, 2021, 04:18:30 PM »
That's it! I moved a ground wire to put the .15 caps and pin 13
at the same point and it cleared up. Thank you.
I upped the 100uf at the output to 470uf also (before I changed the ground)
and that helped also. What is the affect of using .22uf rather than .15uf?
Gus:
I am using an 8 ohm speaker.
Basic Audio Pedals
www.basicaudio.net/
antonis
« Reply #4 on: February 02, 2021, 04:27:59 PM »
You're welcome..  :icon_wink:
Next suggestion, in case of above non-effective, should be to delete one of 150nF caps and wire the remainder one between pins 2 & 15..
(to also prevent garbage entering into different points of GND..)
