The only spray can products i used were the etching primer and rubberized rocker panel paints but limits, sometimes a window will be presented, recoat within a certain time, the can will say.
Stick with one company's products, better chance they'll be compatible, trail and error tells you lots, sometimes it's months down the road before things fall apart.
What worked for me was any brand of etching primer i tried, after that heavy air brush use - the Zinnser primer sealer, high solids & good build sands real nice, paints and mediums from Golden, Acrylic artists products, clearcoat with waterbourne lacquers using airbrushes and again here brand didn't matter but it was always ones recommended for instrument finishing, clear not milky like poly's that i tried and no yellowing.
Lengthy process i had time, I'd do a number of enclosures with the etch primer and Zinsser when i could do the etch primer outside in the summer so i had prepped enclosure to use in the winter.
dave
