Author Topic: Thick Film Resistors  (Read 339 times)
spoontex
« on: June 19, 2022, 11:28:11 AM »
Hello,
I'm building a 20 years old project that use this kind of resistors.
TA205PA82R0J
I think that the author select this resistors because the space is very tight, and use to-220 style resistors.
The problem is I can't found this resistors anymore. Anybody know a replacement or a trick suggestion?
Thanks.
antonis
Re: Thick Film Resistors
« Reply #1 on: June 19, 2022, 02:17:57 PM »
TA205PA82R0J datasheet call for 82Ω 5W..!!
I'm not sure if there is enough space for equivalent ceramic resistors..
https://lotos.si/en-US/shop/item/2806100820009
or even for metal-oxide equivalent..
https://gr.rsdelivers.com/product/panasonic/erg5sj820/panasonic-82%CF%89-metal-oxide-resistor-5w-5-erg5sj820/1067506
Hobs
« Reply #2 on: June 19, 2022, 03:32:21 PM »
TA205PA82R0JE is almost identical, and still available.
https://www.digikey.com/en/products/detail/ohmite/TA205PA82R0JE/824299
« Reply #3 on: June 19, 2022, 06:56:20 PM »
What's the project?  If we knew maybe there's better options.
I worked on a high-frequency project which used these because of the low inductance.
They can be bent back and forth an eventually break off.
Send:     . .- .-. - .... / - --- / --. --- .-. -
spoontex
« Reply #4 on: June 20, 2022, 10:29:07 AM »
The project is a tube headphone amp. I think that I try to use metal oxide resistors. This Thick Film are very expensive!!
« Reply #5 on: June 21, 2022, 06:43:35 AM »
Old technology: the candohm resistor, this one being 23K:
