Author Topic: PCB Guitar Mania - Submarine vibe (EQD - The Depths clone)  (Read 935 times)
harrisxr650
« on: January 26, 2023, 07:55:40 AM »
Hi,
I'm trying to add a rate led to this build but i cant figure out how.
 Can someone check the schematic and advise how to if possible?
Re: PCB Guitar Mania - Submarine vibe (EQD - The Depths clone)
« Reply #1 on: January 26, 2023, 08:15:47 AM »
to my unqualified eye, that looks like a phase shift osc based around Q1. easiest way I can think is to add a led and clr in parallel with R22. don't go silly bright - use ultra bright led w/ 22k say - and you might need to adjust R22 a value higher if the oscillator conks.
otherwise, just jamb a led in line with R22. may affect waveshape and oscillation goodness at the extremes of the rate pot.
antonis
« Reply #2 on: January 26, 2023, 08:27:26 AM »
If you want to implement a fancier application..
(although, Stephen's suggestion is true, correct and verified..!!) :icon_wink:
P.S.
100nF cap is optional for LED fading (smooth blinking)..
« Reply #3 on: January 26, 2023, 09:07:27 AM »
antonis - how is your rate indicator getting any information from the oscillator? I can't see it.
antonis
« Reply #4 on: January 26, 2023, 10:07:11 AM »
It doesn't.. :icon_wink:
(in the mean of not directly..)
harrisxr650
« Reply #5 on: January 26, 2023, 03:59:24 PM »
P.S.
So you adding a small circuit for the led with an additional MPSA18 and a couple of components?
out of curiosity, can you explain how this works? i'm looking to learn a bit and not only asking around constantly :D,
Also Stephen mentioned that his way may affect waveform and oscillation goodness at some point, how about your idea?
anotherjim
« Reply #6 on: January 26, 2023, 04:32:20 PM »
I think Antonis is showing a simple level meter. Since it's a vibe, the signal level should pulsate up & down as will the LED brightness. It's a Throbometertm.
Croeso i Diystompboxes.
Cnicht siarad "nee"
antonis
« Reply #7 on: January 26, 2023, 04:48:03 PM »
Stephen mentioned that his way may affect waveform and oscillation goodness at some point..
Try the LED + R22 series combination, making R22 10k (or so) to compensate for LED voltage drop.. :icon_wink:
« Reply #8 on: January 26, 2023, 10:54:24 PM »
This may work. Red may be best.
