MICRO 5 see 6
Started by Phend, February 07, 2023, 10:15:56 AM
Phend
Hello:
Question:
What does C6 do (technically) shown in the upper right between pins 1 and 2.
Changing it does change the sound.
I am thinking of switching a couple or few capacitors.
  • SUPPORTER+
When the DIY gets Weird, the Weird turn Pro.
antonis
It bypasses (shunts) IC1a output signal from been fedback into IC2..
Technically, IC1a is an integrator, by itself.. :icon_wink:
See also C6 in MXR 120 schematic..
Phend
Since this is in the picofarad range wonder how this would work.
It is 365 pF .
Unfortunately my build has no room for it. (Without major surgery)
It is ~ 1.2 x 1.2 x 1.2 inches.
  • SUPPORTER+
Dormammu
Quote from: Phend on February 07, 2023, 11:22:16 AM
No big deal.
In the shown diagram, caps are in microfarads. A variable cap from the radio won't really work.   ;)
FSFX
#4
Quote from: Phend on February 07, 2023, 10:15:56 AM
Hello:
Question:
Just try a few different values of R6 or make R6 variable as that works in combination with C6 to determine the characteristics of that integrator type of circuit.
Phend
#5
Decided to use an ON ON ON switch.
Will put 1nF in the middle and be able to put 2 others in in parallel.
Like the sound of 0.47nF and 1nf.
Plus another // selection which have have yet to test.
All started with Deadastronauts 3-4-2013 post :
"sounds cool, if a little weak on the envelope..
swapped C6 for a 1nf.....better sweep lo/hi....(in the pf range its mental brightness..but cool too.)"
  • SUPPORTER+
