Mute Mutations (Experimenting w/ LFO Driven Mute Circuits)
Started by Ohioisonfire, February 10, 2025, 01:57:26 PM
Ohioisonfire
Hello Again,
I have been working on an automatic mute/stutter/square wave tremolo circuit for some time. In summary, an LFO driving something that would mute the signal on and off constantly.
Originally I intended to use relays. I breadboarded this and was overall quite happy with the result. I decided to move on from this for a number of reasons, but the two biggest factors were relay lifespan and current consumption.
The next circuit tested was opto-fet/opto-coupler/whatever you call them devices (TLP222 or similar). These seemed attractive as they are very easy to drive and solve my two biggest complaints with the relay. However, I could not get the clicking/popping quiet enough with the circuits I tested. I suspect this is the result of these devices rapidly turning the audio on and off without any consideration for zero crossing or similar. I also have obsolescence concerns with these parts. Would be happy to dive deeper into these if someone thinks the clicking/popping can be tweaked out.
I am now looking into JFET mute circuits since I can control the on/off speed, thankfully there are a lot of resources available on designing these circuits, unfortunately most of it is geared towards dual rail supplies. Something I would like to understand better:
  • I understand for a series JFET mute, the gate voltage needs to be bigger than Vgsoff + signal Voltage. This gives a sort of "headroom" as to how much signal can be applied and the mute still function properly. Does this also apply to a shunt mute?
Based on what I've learned so far, this is the circuit I have come up with. I chose a P-Channel JFET so that I can negate the need for a negative voltage by referencing the source and drain to ground and the gate to V+. Would love to use something like a J111 for its lower on resistance, but do not have enough supply voltage. Please ignore the incorrect schematic symbol for the JFET. I plan to experiment with two JFET mutes in series for better "offness" and/or a series/shunt mode hybrid circuit.
Some time ago, I designed a signal switching circuit that could accomplish noiseless switching with 4066 CMOS by determining when the two signals were equal and switching at that point in time to ensure there was a minimum of switching pop.  Look at the last picture in this thread:
https://www.diystompboxes.com/smfforum/index.php?topic=120006.msg1122294#msg1122294
This could be simplified for your needs because one of the inputs is zero signal.
Ohioisonfire
Quote from: amptramp on February 11, 2025, 08:26:13 AMSome time ago, I designed a signal switching circuit that could accomplish noiseless switching with 4066 CMOS by determining when the two signals were equal and switching at that point in time to ensure there was a minimum of switching pop.  Look at the last picture in this thread:
Thanks for sharing this! Still studying these circuits and devices trying to understand how they work. I would assume for this application, instead of switching when the two voltages are equal, I would want to switch when the signal is crossing zero? Trying to wrap my head around how that would work with the timing of the LFO as well..
