Aion Straylight in a 1590BB2?
Started by peAk, April 27, 2025, 12:53:07 PM
peAk
I see in the documentation that it states that a 1590BB2 is about 4mm too short to accommodate the light shield. Also, there are a few electro caps on the stomp PCB that are too tall.
Obviously the caps on the stomp PCB can be bent over but was curious if you omit the light shield once biasing, would it be possible to fit into a 1590BB2? I like to get my enclosures and UV printing from Tayda and they dont offer the 1590BBS
"....we took an entirely new approach, using interlocking PCBs to build a light shield...
Our light shield is not a requirement for the build. The slotted pads on the PCB can fit a variety of other solutions, such as a sheet metal box bent to the right size (0.8" / 20.3mm square)..."
https://aionfx.com/app/files/docs/straylight_documentation.pdf  page 4
peAk
Quote from: PRR on April 27, 2025, 01:18:08 PM"....we took an entirely new approach, using interlocking PCBs to build a light shield...
Fair enough, thanks
was more just curious if anyone has done it and what they did
