AionFX Quartz (Diamond compressor) - unity volume fully dimed, LED always red...
Started by loves_guitar, Today at 12:17:56 PM
loves_guitar
Hey rockstars,
Building myself a bass pedalboard and wanted to build a couple pedals for it.
Boxed up AionFX's Quartz project (Diamond compressor) with the bass substitutes.
Bypass works. Engaged works. EQ knob makes tonal changes.
However have to fully crank the volume knob to achieve unity gain. Don't think it's actually compressing (if it is it is really, really subtle). Built it with the bi-colour LED from Mouser but it is always red, doesn't start green and then go red when compressing.
Using LM358P and OP275 ICs from Mouser. Other than the pin for the ground and the voltage supply, getting roughly 4.4v on all of the pins on both ICs (just using a 9v Boss power supply for now - have a passive P-bass so not worried about using 18v for now). Confirmed the transistors are in correctly.
I'm stuck.
Thoughts?
Quote from: loves_guitar on Today at 12:17:56 PM4.4v on all of the pins on both ICs
ALL pins? Then you have a wiring error. You expect zero one place and +9V another place.  Show what you did.
BTW: https://aionfx.com/app/files/docs/quartz_documentation.pdf
loves_guitar
Quote from: loves_guitar on Today at 12:17:56 PMOther than the pin for the ground and the voltage supply....
Pins 4 - ground
Pins 8 - just under 9v
I'll upload a picture of the board after work.
loves_guitar
All good, PRR!
Just watched a demo and maybe this is operating as-designed. It's more subtle than I remembered.
