Grounding pedal enclosure via an Alpha 9mm pot
Started by FleshOnGear, May 07, 2025, 09:25:38 PM
FleshOnGear
Hello, I'm curious if anyone knows if the mounting clips on the back of an Alpha 9mm vertical pot conduct to the top of the case and the bushing. I was hoping to ground my enclosure by soldering one of the mounting clips to ground on the pcb. Will this work?
merlinb
I have a bunch of those on my desk. Yes, the mounting pins have continuity with the bushing, so you should be good.
FleshOnGear
