loop box.......
Started by mcv, January 12, 2004, 04:55:53 PM
mcv
i want to build a loop box; for hooking up my pedals through the loop, and when switched i want to go straight to amp.
any directions?
Skreddy
The classic DPDT version (no LED)...
and the 3PDT with LED...
Mike Burgundy
That's an A/B box, isn't it?. A looper has in and out, plus connections for an "effects loop (send/return)
It can be done passively, but why not add a blend knob?
The paralooper at Moosapotamus' site will do nicely: you can even do away with the filter section opamp and circuitry and just put a short in it's place.
Build the whole thing though - great little tool for both guitar and bass. If it's too ballsy, replace the 10u with 1u and remove the filter cap (.047, Moose has this paralleled with a switchable second cap on the pcb) or make it a lower value.
hih
You might want to take a look at GEO - see "Jimi in a box".
dan
i'm planning on making one too.
i found this:
http://www.geofex.com/Article_Folders/rmtswtch/rmtsw.htm
but too me it just seems like i don't think it could work as a bypass box, i prolly just don't understant it.
then i found this:
http://geofex.com/Article_Folders/fxswitchr/fxselex1.gif
this seems simpler and is what i'm using. hell, for all i know they're prolly both the same, but i know i understant that one. good luck.
-Dan
Skreddy
Oh yeah; sorry!  My brain was tired obviously.
