Unity gain/voltage follower question...
Started by ExpAnonColin, January 19, 2004, 12:23:23 AM
ExpAnonColin
So where does the Vbias go?  There's nothing grounded on a voltage follower, just the V- and V+ of the op amp, so how do I trick the op amp into using the ground?  Can I just do ground and not worry about a vbias or is there another special trick?
-Colin
Peter Snowberg
Followers don't use Vbias, unless the follower is AC coupled in which case a Vbias of high impedance is connected to the signal input.
Take care,
-Peter
Eschew paradigm obfuscation
amz-fx
Colin, look at the way the opamp buffers are configured in my article at:
http://www.muzique.com/lab/buffers.htm
regards, Jack
