runoffs EA tremolo
Started by marrstians, January 24, 2004, 02:19:12 AM
marrstians
hey... is there a way to make the depth deeper or more drastic?...
LDR...gets a little bit choppy
 For more choppy I would recommend another one like the pulsar...Never tried it.
 Look for something non LDR if you want fast hard chops. square and triangle waves give different effect on Trem LFO's.
gez
Quote from: marrstianshey... is there a way to make the depth deeper or more drastic?...
You need more of the LFOs output signal across the pot which sets the depth.  Either make the 68k bigger/ use a larger value pot/reduce the 120k (though it would be advisable to increase the 68k at the same time to avoid loading down the output of the LFO).
Just tweak this resistor chain and you should get some joy, though there's a limit to how far you can go so don't expect too much.
smoguzbenjamin
Lower the resistor between the depth pot and ground or the LFO output, I can't remember... :?
RDV
You want choppy trem? The Kay tremelo is all chop!
Regards
RDV
