quick, dumb question
Started by Luke, January 28, 2004, 08:52:56 AM
Luke
Hi guys,
I am trying to de-bug my fuzz face, and have a very stupid question. I am debugging using the 'beeping' function of my DMM. I have all beeps (thus current) until I get to my first cap. It beeps on the negative side (where my signal is comng in) but not on the other side. Should I hear a beep on the + side of the cap? Maybe I have a bad cap? I am doing the boutique fuzz face, neg ground (from ggg)
please help!
Cheers,
Luke
Marcos - Munky
I think this can be a bad cap or bad solder connection. Try to use a audio probe (take a look in geofex.com), this will let you know where you are loosing the signal.
Luke
thanks Munky,
I am not being arogant, but I am postive its not a dry solder :D . I am always careful to make sure the solder is ok- (and I just re-soldered  the connection after your advice) :lol: it didnt work :cry:
thanks though- I will try to make an audio probe soon.
thanks man,
Luke
spongebob
Quote from: LukeShould I hear a beep on the + side of the cap? Maybe I have a bad cap?
No. The capacitor blocks DC, and I think that's what the multimeter is using in "beep" mode.
Best way I've found to test caps is use em in an audio signal path and see if 'sound' goes through.
 My DMM has no real way to check caps AFAIK.
 I never really had a cap problem per se'...as far as a faulty component.
Marcos - Munky
Maybe the problem isn't in the cap. I suggest to you resolder all the solder points, if this don't work, try the audio probe or change the cap for one with any value, just to check if the circuit work with another cap. If the circuit work, just change the cap for one with the same value or one that sounds cool for you. You don't need to remove the cap to test the circuit with another cap, just connect a cap in the wires of the soldered cap, but if both caps are working you will get the sum of both values I think.
smoguzbenjamin
The beep mode does test for continuity, you know that right ;) If there ain't a direct connection without resistance it won't beep ;)
aron
You cannot test a cap with the continuity feature. The continuity feature of most meters will only beep when there is very low resistance.
See this link for more details:
http://www.repairfaq.org/sam/captest.htm#cttcm
again, thanks to R.G. for finding this great link.
Alpha579
as someone above said, its most likely the beeper reads DC, and capacitors Block DC.
Alex Fiddes
Luke
thanks guys,
thats what I origionally thought.
I will bugger around with this circuit for another few hours, then, if its not going, make it the PNP positive ground. I have read that alot of people seem to have probs with the negative ground circuit. i am SURE that I have perfed it correctly- re tested every joint. Granted, this is my first time using Ge, but I am used to the circiut going first try!
Arghh!
but thanks for the adviceand info!
Luke
