LPB Fuzz
Started by Willthebold, January 30, 2004, 12:02:16 AM
Willthebold
Just finished putting the LPB together and I'm getting fuzz at all volume levels.  It goes away when I turn the guitar volume down a notch or two, so I guess my pickups are just a little to hot (Gibson SG).  What do you guys recommend to help feed the unit a better signal?  Is it the input capacitor that controls this?
Will
Ansil
use a trim opt on the emitter resistor it will help it clean up.
Willthebold
Did you mean on the emitter of the transistor?  About what size?  I'm assuming something small, maybe 500 ohm?
Will
Ansil
Quote from: WilltheboldDid you mean on the emitter of the transistor?  About what size?  I'm assuming something small, maybe 500 ohm?
Will
1k  is fine.  to replace the emitter resistor,  500 ohm if you wish to add it to the resistor all ready there
smoguzbenjamin
The emitter resistor is the resistor between the emitter and ground ;)
However if you like that Fuzz try another booster in front or behind that one...with a pot between them and at the end er what...mess with some values there...can get cool OD tones from two little Boosterz
