Ts-808 without diodes? still worked..why?
Started by jimbob, February 03, 2004, 10:00:46 PM
jimbob
I forgot i took my diodes out to use in another effect i was working on so when i plugged the ts808 in and played through it still worked..Why..didnt sound all that bad..
"I think somebody should come up with a way to breed a very large shrimp. That way, you could ride him, then after you camped at night, you could eat him. How about it, science?"
brett
The signal can't go lower than 0V (ground) or higher than 9V(supply).  In fact, with an old RC4558 chip in it, it'd be lucky to go as low as 2V and as high as 7V.  So you still get clipping, just a volt or two higher and lower than with the diodes.  Tho I am surprised that the clipping is musical.  My experiences with lack-of-headroom clipping in op-amps (by deliberately mis-biasing them) is that it's not very musical.
Brett Robinson
Brian Marshall
yeah, i tried building a 4558 fuzz on bread board.  it sounded terrible, but maybe since the TS cuts so much bass it might not be that bad, but i can immagine it would sound good.
brian
