BRIAN MAY BASS BOOST?????
Started by Ricardo Antunes, February 04, 2004, 11:08:14 AM
Ricardo Antunes
Hy, friends
-I just built the "Brian May treble boost", from Generalguitargadgets... and.....SURPRISE!!!!! There´s no treble boosting, only sustain and bass was boostered. I used the NPN 2N3904 ( the other parts in stock values), and it caused some distortion in the clean sound...not bad, but it has too much gain. I tried another NPN (BC548C). This time there´s not distortion but the bass boost was there ( a bit of hiss and hum too). I play trough it with a Les Paul. What´s happening here?
-Another little doubt.... How can I add a tone control to a NPN Fuzz Face basic circuit?
Thanks all
Mike Burgundy
this should almost 100% sure be a wiring error: a cap to mass instead of in-line, so the whole thing is low-pass instead of high-pass. Something like that, anyway. Perhaps a feedback loop that's wired wrong? Check and double check.
Tone control: stick a bigmuff or other control (tone-plus-volume-knob as one building block)of choice in the place of the existing volume knob. Done. Tinker with the values to get a response you like - also take the existing output cap along in that.
hih
Boofhead
Another possibility is the 1nF cap across the base and emitter of the transistor is the wrong value.
Chris S
I built one by the same schematic and it does have a huge volume boost, I beleive thats because we are using the new plastic transistors rather than the germanium one that would have been put in the original. I took a few goes to get the wiring right too!
Doug H
Quote from: Chris SI built one by the same schematic and it does have a huge volume boost, I beleive thats because we are using the new plastic transistors rather than the germanium one that would have been put in the original. I took a few goes to get the wiring right too!
I found that low hfe (200 or less) transistors sound best with this. 2n3904 should work fine.
Doug
Gearbuilder
Hi,
i've tried several transistors before mine was ok,the trans was from an Old Simms-Watt Amp .The sound is really like Brian May.Make sure to use a tube amp with it.
Bruno
