I have a Keeley RAT and...........
Started by timrand, February 12, 2004, 08:17:52 AM
timrand
Well
I thought I would invest in a RAT and after searching around I thought I would spend the extra and buy a Keeley modified RAT. OK the pedal sounds great in the Keeley mods mode;s however the actual pots are really touchy I don't turn any pot above 7'o'clock the gain is crazy the pedal sounds awesome however completely UNUSABLE in its current form. I got caught up in the harmony central Keeley is great he always reply's to your emails I only have had one reply out of 8 that was to thank me for the order. Now I am searching for a linear pot to replace the log pots as I have just come back from rehersal and adjusting the volume with my big toe I need more range in the POT. Sorry Keeley but the pedal sounds great but I can't understand how you can send it out like this. Can somebody send me in the right direction to source a linear pot ?
Cheers
Marcos - Munky
If you know the value, take a look in local stores, I think they have the pots. Ask for mini pots, they are smaller and cheaper, if they don't have ask for common pots. Or maybe Small Bear.
smoguzbenjamin
Mini pots cheaper? Not where I live, they charge double for mini pots!  :x
Marcos - Munky
Here they costs R$1.50 ($0.50 in dollars). The common pots costs R$5.00 here ($1.70 in dollars).
smoguzbenjamin
You lucky mite! :x I pay way too much for pots. I must stock up with smallbear :D
