controlling pedal volume in fx loop
Started by Greg M., February 29, 2004, 10:35:31 PM
Greg M.
I have a Guyatone TR-3 trem that I run through my amp's effects loop.  It sounds fine but it gives a volume boost that I hate.  Is there a way I can turn the volume down after the pedal and before the amp to equalize the overall volume?  I've seen a pedal that is basically a volume pot and would probably work but it's too pricey for me.  Is there a simple way I could build my own?  Any suggestions would be appreciated.
Fret Wire
Fret Wire
(Keyser Soze)
Why not put two resistors inside the pedal that act like an internal fixed volume control?
Greg M.
R. G., how and where in the pedal would a novice such as myself add the resistors?  Is it relatively easy to do?
