Blue Magic ?
Started by gtrmac, March 04, 2004, 10:10:38 PM
gtrmac
The Blue Magic schem from GGG calls for a 6.8uF polarized cap off the source of the MOSFET. Is it advisable to use a Tantalum cap here? I can't find anything else with this value. If so, how many volts should I use?
Don't exceed battery or supply voltage [wallwarts may stray from what they're marked as] for what your caps are marked...supply voltage plus some headroom...16v caps with 9v supply is what you'll probably find.
 I've used 10v caps, but I don't like to.
 make sure you follow the polarity of caps marked as polarized.
gtrmac
Thanks, I guess I'll have to use Tantalum caps. I haven't found anything else at 6.8uF. Even these are only available at 35V locally.
I hope that Blue Magic lives up to it's name.
Boofhead
You could use a 4u7 in parallel with a 2u2, that will give you 6u9 - the difference to a 6u8 is below human detectability (and part tolerances).
You can find 6u8 non-polar electrolytics fairly easily.
Ge_Whiz
QuoteI hope that Blue Magic lives up to it's name.
I can assure you that it does, although I raised the mid-boost capacitor from 500pF to 1500 pF (1.5 nF) to be able to hear the difference. Tin ear, I guess. Oh, and I put a 4k7 resistor in between the drive pot and ground to stop the drive pot going right down to zero ["Hey? Where did the sound go, dude?"]
Paul Marossy
I like my Blue Magic!  8)
WGTP
I would suggest you use a socket there and try a 4u7 or 10uf electro to adust the bass.
Stomping Out Sparks & Flames
