The sad SAD1024A
Started by Dan N, March 15, 2004, 05:11:33 PM
Dan N
Hi guys,
I just bought a broken Deluxe Memory Man from ebay. Of course I was hoping it would be a cheap and easy fix.
Oh well...
Guess I better find out what blew these suckers up before replacing them.
Dan
Peter Snowberg
Ouch! is right! :(
I'm going to guess that was a power supply mishap.
Best of luck on your repair. That really brings new meaning to SAD 1024.
Good luck,
-Peter
Eschew paradigm obfuscation
phillip
Holy crap!  Those things must've gotten HOT to burn holes through them like that!
Does the Memory Man have a built-in 120V power supply?  If it does,  I would suspect something in that area...that would be about the only thing that could send enough juice through there to fry those chips that bad.
If it has a DC power jack, then someone could've plugged in a wall wart that had way too much voltage and current.
Phillip
Hal
at least one of 'em looks good :-D
Fret Wire
The 1024 on the far right looks like it has two pins cooked off. WOW! $15 a pop for these bad boys! I feel your pain :cry:  With some good hunting, you may luck out and find a quad of these cheap.
Is there any evidence of ametuer hacking in the circuit anywhere? Maybe this guy used his 5000W camp generator for a wall wart.
Fret Wire
(Keyser Soze)
Dan N
It does have it's own power supply. I get 34 VAC from the transformer secondary, and a DC power supply of 15VDC. The only voltages I get from the delay chip sockets is about 4.5 volts on pins 2 and 15. The other opamps are getting the 15 volts.
No hacks as far as I can tell.
I have to trace this thing a bit before I try to do anything.
That one good looking chip on the right looks like it was a replacement. While not exploded, it has a carbon trace jumping the pins and it's socket was really powdery with carbon.
I have 2 1024's still in their Radio Shack bubble package so I'll only need 2.
Funny, I can dive right into a live tube amp without much fear, but working on this little box with the AC on just scares me!
niftydog
I can work near 25kV all day... but the second something goes bang, or there's smoke, or visible damage like this, it gets a little edgy around the workshop!
Just something about that subtle reminder of the power of electricity...
electronic eng. humble pie recipe;  hook up a 50V cap, backwards, to 200VDC and stand well back!
niftydog
Shrimp down the pants!!!
drew
I'd cut your losses, re-ebay it, and get a used-but-working one instead! I would cry if you blew up those 1024s :)
drew
www.toothpastefordinner.com
The folks who were pedalling a "reworked " MXR Analog Delay with a daughter board using a PT2399 had the right idea.  Not only is it going to be expensive to find and buy a quad of the 1024s, but  the sound quality will not likely be much better, nor will the delay time be any longer.  Does *anyone* really want to contend with 4 sets of trimpots?
Impaler
Looks like one of the military's scatter bombs went off in there
"You're just another victim" - Tazz
