amp help O.T.
Started by Vincent Volta, March 28, 2004, 08:25:37 PM
Vincent Volta
Hi evryone!
I built a small amp based  around TDA 2003 chip, 7 to 8 watts of power. It works fine but the problem is, I want to put a headphone jack on it and I dont know where. The schem is found almost anywhere, its the one that comes with factory specs and data sheets. Any clues? Ive seen a particular Hondo amp with a similar circuit taking the speaker output directly but I dont know how safe this is... thanx in advance.
May the yoghurt be with you.
Ansil
do you wish to have it eliminate the speaker out when you do so or just as an extenral source of sound for headphones
personally i would put a small pot on ther, and a jack
of course you can just put like a 100k resistor off of the speaker otuput and then a pot to help limit the sound from kilin your headphones and more in protanlyt your ears
