I need technical info about M5218 OP AMP
Started by mr_winter_, April 27, 2004, 02:29:08 PM
mr_winter_
HI EVERYBODY!!!
I tired of search with no results any datasheet of M5218 (very used by BOSS) or somethig that tell me wich is his pin out ...
is the same that TL072/4558???
or is like a 741???
I don´t now!!!
please any help!!!
thank you friends!!!
You should read 9v somewhere on one of it's pins. Gnd is probably pin 4.
 Might tell you a little bit about it, or what Might work in that spot.
RDV
According to : http://www.fibra-brandt.com/, their equivalent is the MC1458, in other words; it's a standard dual OA.
HTH
RDV
mr_winter_
Thank you RDV!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tim Escobedo
It's pretty equivalnt to a 4558. I have a pdf datasheet if you want.
mr_winter_
Ok tim!!!
send me to:
albertocastillo@hotmail.com
very thank you !!!!!!!!!!!!!!
The pinout on the DIP version is the same as the 4558.  The pinout on the SIP version (which tends to be why Boss uses them...smaller space) is also the same but obviously with 8 pins in a row, pin 5 is located differently than on a DIP.
The datasheet indicates it is a "general purpose" dual op-amp but is low noise, low distortion, moderate slew rate (3v/us) and can run off supplies as low as 4v+.  So, a 4558 *will* replace it but isn't quite as high quality a device.  That may be a good thing or a bad thing, depending on the application.
Dai H.
Those sound bad for passing basic audio, IMO. I've tried changing them for 5532Ss in some Boss efx., and that's what I found. (Kind of gritty, harsh.) Might be just fine or good in some situations like Mark has mentioned, though.
mr_winter_
thank you friends!!!!!!!!
you info is very use full!!!!!!!!!!!!!!!!!!!
thank you to everybody!!!!!!!!!!
