i need a cheap quick build...............
Started by el duderino, April 29, 2004, 02:01:44 PM
el duderino
hey i need a cheap build that i can make form some of my left overs any ideas???????? :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :shock:  :!:
you can keep my finger nails clean
lightningfingers
depends largly on what "leftovers" youve got
bass fuzz
electra distortion
little gem etc
U N D E F I N E D
Transmogrifox
Boosters, like MOSFET and LPB if you have extra BJT's or MOSFETs.
You could do a passive eq, like use a Big Muff tone stage if you want to use up some resistors, caps and a pot.  This would be useful for pre-coloring your guitar, or using it as an extra in-line tone control for distortions.
Op-amps are always good for boosters.  I have seen various schematics around for op-amp boosters.
Fuzz distortions are usually minimal parts cheap build pedals.
The Vox Treble Booster is a very simple build.
trans·mog·ri·fy
