Output buffer
Started by jjucius, April 29, 2004, 07:15:49 PM
jjucius
I am building an output buffer for my wha and i was wondering where to connect it to? all it says on the buffer is in and out. the buffer on runoffgrove says lug 3 of the pot and out. can i use the output from the switch? please help i need my wha
Joe
brett
Hi.  If your wah isn't true bypass (I suppose that's 99%),  using the output of the switch will leave your buffer in place regardless of whether the wah is used or not.  That *might* be a good or a bad idea.  If you want to preserve the "feel" of pedals further up the line (when the wah is off) I'd switch the buffer in and out with the wah, which means connecting between the buffer between the pot and the switch.
I've wired mine both ways but now prefer to switch the buffer too.
have fun
Brett Robinson
jjucius
