a/b box...bad HUMMMMMMM
Started by tele_guitarist, May 03, 2004, 11:56:32 AM
tele_guitarist
Any idea why? I wired up just like this except I left out the led and used a dpdt. Here is the image layout:
http://smallbox.zeonhost.com/projects/abbox/
Thanks for any help!!
Eric H
Probably a ground loop --what are you using it to switch?
-Eric
" I've had it with cheap cables..."
--DougH
Any time you connect the grounds on multiple effects and/or amps, you take the chance of introducing ground loop hum. For why this should be so, read the "Spyder Power Supply" article at GEO.
For how to get around it, read the "Hum Free Signal Splitter" article at GEO.
Hmmm... better yet, read all of the stuff at GEO.
tele_guitarist
Quote from: R.G.Any time you connect the grounds on multiple effects and/or amps, you take the chance of introducing ground loop hum. For why this should be so, read the "Spyder Power Supply" article at GEO.
:lol:  My newbiness is that apparant, huh?  :lol:
I'll check it out, rg, thanks!
I'm using it to switch between two amps. If only 1 amp is on, everything is alright. But, when I turn the other amp on...HMMMMMMMMMMMMM!
Thanks guys!
