pcb design
Started by leonhendrix, May 06, 2004, 05:37:46 AM
leonhendrix
I've made my fist pcb design of a univox super fuzz on express pcb and i want to post it so i could get some feedback about it but i dont know to get it on here
leon
niftydog
First you need to be able to upload images to a publicly accessible web server, then you post the link here inside an "Img" tag.
Do you have photoshop or paint shop pro or similar?!  try to work out how to do a screen capture.
in paint shop pro, you go FILE, IMPORT, SCREEN CAPTURE, START.  Switch to Express PCB, right click to begin.  Now just draw a marquee around what you want to capture, save the result as a jpg then post it.
Or you may be able to use a print driver utility such as Universal Document Converter to "print" the file to a jpeg file.
niftydog
Shrimp down the pants!!!
bwanasonic
If you are using ExpressPCB, hit the *Print Scrn* key on your keyboard. Now go to MS Paint and edit/paste. Save this file locally. You will then need a web-hosting *home* for this file. Then use
to display the image in a post.
Kerry M
