tv tube
Started by changes, May 07, 2004, 06:30:33 PM
changes
well here is probably a crazy idea...I've built some pedals but i don't have a clue of anything concerning tubes...i have a tube (PGL-66) that i ripped out of an old tv...can i use it for any sound application?
CHANGES
Peter Snowberg
I don't recognize the part number. Do you have any more identifying marks like number of pins, base size, etc?
Take care,
-Peter
Eschew paradigm obfuscation
changes
well might be mistaken cause the letters died away...
it has 9 pins
and as far as i can read says
YUGOSLAVIA PGL-66 (could be PCL-66 not sure)
it also has a symbol like "Ei" probably the brand
did that help???
CHANGES
puretube
PCL86 ? eq. of ECL86 (=6GW8) , but the >P< stands for diff. filament,
in this case: 14.5V, 300mA;
the >C< stands for triode, in this case eq. to half a 12AX7;
the >L< stands for (power-)pentode, in this case eq. to EL41, the older (and a little less powerful) brother of the EL84 (9 instead of 12W);
yes, is use-able for audio...
14GW8 is the american name for the PCL86.
>Ei< is the yugoslavian manufacturer (not sure about the name of that country right now, though  :oops: ...
changes
yes
the first number isn't very clear but now you say so i think you're right...
well what about that part???
CHANGES
puretube
just imagine you got half a 12AX7 plus an EL84...
in fact the plate-impedance (= outputtransformer)
should be a little higher than the usual EL84 trafos,
but if you stay under 250V B+, it`ll work ok if you keep
the plate current around 35mA.
make a nice clean 5W practicing amp...
(use the right heating!)
Pull the tube out of there, with the related guts?
 I know separating the sound tube's circuit from a TV would be involved, but there it all is...might have to drag the whole TV around, or make a different power supply...involved... :roll:  :lol:
