Printing PCB trouble
Started by robkeeler, May 08, 2004, 01:24:05 AM
robkeeler
I'm having trouble printing the pcb transfer from fuzzcentral and generalguitargadgets.  The pcb I'm having difficulty with is the Foxx Tone Machine.  When I reduce the image to the correct size the image becomes all jagged (on the screen and the actual printed version).   Any way to smooth out the solder lines on these pcbs?  BTW I'm on a mac so I can't use the reconmended wingif app.  Thanks
MarkB
Don't reduce the size - adjust the resolution of the image.
If you have something like photoshop - change the image resolution to 300dpi, without resampling.. that should work for you.
