AMZ mosfet boost, mod.
Started by cedric, May 18, 2004, 05:12:52 PM
cedric
put a 500k pot just before the output, and you'll be able to get al the grit you need without boosting the volume (this'll be your new volume knob).
and the 'boost' knob will be the GRIT knob. voila - overdrive-box!
- ced
That AMZ Mosfet can BOOST !!!!!!!!!!!!
 I should put the 'other taper pot on my gain knob.
ryanscissorhands
ced, have you actually built this mod, or just imagined it?
AND, anybody have some good sound clips of the AMZ mosfet overdriven (and/or clean)?
Gringo
One small mod suggested at AMZ is to add a spst switch to engage/disengage the 100uF cap, to go between buffer/booster mode.
Simple and very useful.
Cut it large, and smash it into place with a hammer.
http://gringo.webhop.net
