Analog Switcher ?
Started by Lonestarjohnny, May 31, 2004, 04:17:40 PM
Lonestarjohnny
I found 5 Potter Brumfield KH-6041 relay's in a box of stuff I had stored back, they can be run on 6 V.D.C. to 120 VDC, 4PDT, Would these make a good Basis for building an analog switcher ?
I would be grateful for any thought's or input on this,
Thank's,
JD
niftydog
http://my.execpc.com/~indelect/potter/pb077.html
hard to say, to me they sound like they're a littly clunky for audio switching.  At the bottom of this page there's info on product numbers, perhaps you can make sence of the number 6041.
niftydog
Shrimp down the pants!!!
Lonestarjohnny
Checked it out earlier, I thank you though, these are a little more compact than the Italian made relay's inside the Bradshaw switcher, and a better quality relay by far, I once wired a 152 relay page on a SCR drive unit, I don't think I ever want to do that again,
I'll keep testing these for now and until I find a better way.
JD
xcpointx
out of interest what do you use to trigger the relays?
Lonestarjohnny
I think the way I'll energize it is with  24 VDC, it's marked on the side of all Potter Brumfield relay's the min. max. operating voltage, these are 24 V. 4 pole, double throw, that give's me quite a bit of option's to do my routing of several of the Emulating pedal's into a tubed power amp, I have several choice's, I dug out a 150 watt Yamaha power amp today, has 6 - 6L6 power tube's with 150 watt rating,which would push my 6X10 cab with no problem, and this amp has no preamp in it, just a mixer for bringing a signal into the power section, this would give me the choice of putting all the board's from several emulater's in one long stomp box, which would be a good way for me to do this, I could also add a volume pedal and a Wha into this stompbox idea, and a pocket to park my tuner in, if I decide to do this then the board will be powered by 120 VAC, in side the stomp box I'll have to add a couple of regulated power supply's which I can build for the 24 VDC, and 9 VDC for my Emulater's. I think this approach will suffice til  I find a better way,
JD
