A LED indicator for a Ruby (on/off indicator)?
Started by Mann, June 01, 2004, 06:44:28 AM
Mann
Just finished a Ruby and it worked right away and now I'm about to build a wooden speaker box and put the whole thing in - a mini amp. I'm going to put a simple on/off switch to the 9 volt + lead but if I wanted a LED indicator where and how should put it?
BILLYL
Mann-
I basically added the LED to the switch ( I have a switch attached to the end of the volume pot)  Using the proper resistor - hook up the LED so that when the switch is on the LED is on.
Hope it helps
BILL
niftydog
Dude, buy a low voltage illuminated switch and save yourself a bit of work!
niftydog
Shrimp down the pants!!!
sir_modulus
Go Here for an led calculator (tells resistance needed). Just put a DPST switch ( DPST = on and off for two poles). Just connect +V from supply and the circuit voltage input to one pole, and on the other pole have +V on one side and the LED with correct resistor on the other (going to ground).
Hope that helps
