"fetzer valve amp" schematic....
Started by casey, June 11, 2004, 01:21:57 PM
casey
does this schem. look right?
any improvements?
i'm working on a tube amp version......  should be cool.
http://www.freewebs.com/outofbrokeness/circuits.htm
Casey Campbell
Eric H
You might want to add an "output" indicator ;)
I'd make the dc filter cap (2,2uf) larger --47uf to 100uf .
-Eric
" I've had it with cheap cables..."
--DougH
Lonestarjohnny
and maybe a Master Volume so you can control the gain and volume, also shielded input and output wire would help keep thing's a little quiter.
Also on the Fetzer Circuit they forgot the 100uf filter cap on your 9 v. input,it should be axial or radial with the plus side of the cap going to the battery.
JD
casey
ok, ill try that out j.d.
it'll take me a few seconds....
hey erik,
thanks...how's that look...
Casey Campbell
casey
how do i control the volume of the output stage without putting a rheostat
at the end of the circuit?
Casey Campbell
Eric H
Quote from: caseyok, ill try that out j.d.
hey erik,
Great --add another R/C filter to the preamp 9v input (or run a line over to the TDA input).
-Eric
--DougH
casey
Casey Campbell
Lonestarjohnny
You could also do a Fender style Bass & treble tone stack somewhere there at your volume pot if you wanted to.
JD
spongebob
Personally I like the idea of using FET emulations as the preamp stage for chip power amplifiers, I connected  the runoffgroove "Eighteen" to a TDA2050 (~30 watt) chip, into a 12" speaker, killer sound! I wonder why commercial manufacturers insist on using opamps/diodes for distortion in their SS amps...
Oh, and if you really want 8 watt output you should increase the supply voltage a bit! 8)
Nice page with tonestacks:
http://amps.zugster.net/articles/tonestacks/
casey
will the j201 handle 12v, cause if so, then i can just put them
both up to 12v....i just didnt want to because of the convenience
of one power supply or the easyness of the circuit...
thanks.
Casey Campbell
spongebob
yes, not sure what the limit is, but 12V will definitively do no harm, even 20V would be ok, I think.
Make sure your capacitor voltage ratings exceed the power supply voltage.
casey
Casey Campbell
Lonestarjohnny
Casey, the J201's are rated to 20 V., but the higher voltage you run them the hotter they get and that mean's for every 10 degree's hotter you can double the ta draw, so if you loose 1 you might have to heat sink them or back down on the voltage some, you got a nice build going, let us know how it turn's out, I've got to where I can't stand my PV without the Fetzer being turned on all the time, it give's the tone and the extra gogettum that my amp don't got.
JD
changes
would any other chip do?
like 4558
or TL072 etc...
CHANGES
Eric H
Quote from: changeswould any other chip do?
like 4558
or TL072 etc...
The tl072 is very similar in specs to a LF353 and would work well here.
-Eric
--DougH
Prive
Quote from: Eric H
like 4558
or TL072 etc...
-Eric
Sorry guys, the TDA2003 is a 5 pins power amplifier with 10W at 15V, it isn't TL072 or op-amp replace.
Saludos, Marcelo.
Fuzz boxes don't need on/off switch!!!!!!!!
changes
the output should go between the .1uF cap and the 1ohm resistor correct?
really cool i would like to see some other schems of amp clones like this....
CHANGES
casey
i have made some minor refinements to the circuit.
Now off to a tube version......
i'm going to need some help on this one folks.....
Casey Campbell
Eric H
Quote from: Prive
Quote from: Eric H
like 4558
or TL072 etc...
-Eric
Saludos, Marcelo.
Haha...that's what I get for responding to more than one post at a time.
Cheers, Marcelo
-Eric
--DougH
