Feedback Loop/ Basic Topology [?]
Started by petemoore, June 12, 2004, 10:05:13 AM
I would like to understand what the topology of a feedback loop [from the output of a TS, to the negative OA input] looks like, or what's in it.
 Having looked at the Overdone FD-1 [a TS type feedback schematic], I can't make out which are the poles and which are the throws on the 3PDT.
  Say I wanted a non-switched/always on FB loop on a TS, coming from output...what would go between output and the OA's negative input.
 Or is the switch necessary for some other reason than to able/disable the FB portion of the circuit?
Eric H
EDIT: After re-reading your post I think you mean the switch that adds another gain-pot to a TS?
> Having looked at the Overdone FD-1 [a TS type feedback schematic], I >can't make out which are the poles and which are the throws on the >3PDT.
I'd like to look too --hard to help without a link ;)
>Say I wanted a non-switched/always on FB loop on a TS, coming from >output...what would go between output and the OA's negative input.
I'm guessing your talking about one of those feedbacker/noisemakers.
Believe me you want a switch, and a pot.
Get a length of wire and put a clip (alligator etc.) on each end, then add a fairly large pot (over 250k), wired as a variable resistor, in the middle of the wire --instant feedbacker. Clip one lead at the output of the circuit, and one on the input, adjust the pot until it makes entertaining noises. Try feeding-back at various other places, until you find something interesting, then add a switch and wire the mess in.
Hours o' fun.
-Eric
" I've had it with cheap cables..."
--DougH
Here's the schematic that got my interests up
 http://www.generalguitargadgets.com/v2/diagrams/ts_fulldive_1_sc.gif
 It looks like there's an 'extra' part or two in the feecback portion'.
Eric H
Pete, the switch is just adding a cap-to -ground at the output (C15) --it just looks like a loop..
The switch-poles are oriented  vertically. the  handle goes up/down --not right/left
Hope that helps
--DougH
Thanks for the help Eric!!1
