Quick Question about pulldown resistors.
Started by bobbletrox, June 18, 2004, 01:23:54 AM
bobbletrox
Should I put a pulldown resistor in a true bypass box?
I've made a bunch of TB boxes in the past without 'em and haven't had any problems with clicks/pops...but the unanswered question is weighing on my mind.
u1061810
HI,
It all depends if you are satisfied with the performance of the switch or not.In general, I believe true bypass wiring is prone to more switch pop than the tone sucking layout.
So it's really your call, if they're quiet enough as is let it be.
