386 question....
Started by casey, June 22, 2004, 10:54:41 AM
casey
i have a question:
can you take a 386 chip and solder it on top of another for a beefed
up little gem?  you would solder pin 1 of the top chip, to pin 1 on the
bottom chip....and pin 2 to pin2, etc.....
would this work?
Casey Campbell
Might be worth a try, I build a 2 into 1 socket/perf  arrangement after burning some chips trying to solder them together...very easy to heat damage chips by touching a hot iron to the pin.
casey
yeah, you've got to be quick....
i wonder if this would work though?
Casey Campbell
lightningfingers
You get the machine pin sockets (not the ones from radio shack) and you can get two into one socket without any soldering. I did that on mine, it increases the output a little.
For a beefed up little gem tho, MkII or the Ruby is a better way to go.
Have fun :mrgreen:
U N D E F I N E D
casey
Casey Campbell
